Відповідна модель
- SRG-X40UH
[How to upgrade]
The installation/upgrading procedure is described on the release note which is included in the zipped download file in this page.
[New features in Ver. 1.10]
Add ICR ON/OFF UVC command, Auto ICR ON/OFF UVC command, and Auto ICR Threshold UVC command.
[Specifications changed in Ver. 1.10]
When USB PRIVACY MODE is "ON", the image quality is changed to the quality suitable for the TV conference and ZOOM MODE is changed to OPTICAL.
[Issues fixed in Ver. 1.10]
Fixed an issue in IR SELECT number of the camera and CAMERA SELECT number of the remote commander are different, when a button of the remote commander is pushed, the POWER lamp blinks.
